| Version(s): | 08.11.09.459 | ||
| Area: | DWG | ||
| Subarea: | Save As | ||
| Original Author: | Craig Calvin, Bentley Technical Support Group |
Batch Converting to DWG failed and message center returns "Unable to save...Status 77847."
The Batch Convert job was set to use a DWG seed file that was unavailable.
If opening a DWG Settings file (DWS) to define "Save As DWG/DXF Options", this file may contain an invalid DWG Seed File path.
To change the seed file used for Batch Converting to DWG/DXF:
Make sure the following configuration variables are not incorrectly set.
i.e. They should contain valid files and paths and the user should have read access for them.
MS_DWGSEED
MS_DWGSETTINGSFILE
MS_DWGDATA
MS_DWGSYSTEMDATA
*What is status 77847 error?
Status 77847 is likely to be associated with a workspace issue.
It must be that your DWG Seed File is not found. It is recommended to manually bring up “DWG SaveAs” options dialog box, click on DWG Seed File and see where this points to. A good chance that it points to a wrong file.
Also do check “MS_DWGSEED, DWG_SEED_OVERRIDE, MS_SEEDFILES” , and other DWG seed file related configuration variables in your workspace. Make sure these are not incorrectly set.
*What is status 77841 error?
This status can be seen when a V7 format file is saved directly to the DWG file format.
When opening the V7 file directly in V8 and not changes have been made to the initial installation, a window will pop up to ask what to do with the V7 file:
Upgrade to V8 format
Open as read only
Since there is no option in the batch converter to answer that question, the configuration has to be changed prior to starting the conversion process by setting the variable:
MS_OPENV7 = 2
Note:
MS_OPENV7 Controls the behavior when opening V7 format files:
0: open with alert dialog (default)
1: upgrade V7 to V8, no alert dialog
2: open V7 as read-only, no alert dialog
3: open V7 for read/write and set workmode to V7, no alert dialog
Setting the value of the variable to: 2 (restart of MicroStation is required) will prevent that the V7 files are being converted and will allow the batch converter/process to run without error 77841.
MicroStation Wiki - Batch Convert Utility
MicroStation Wiki - Save as DWG Error "Unable to open seed file <filename>.dwg"
MicroStation Wiki - MicroStation V8i Variables
Product TechNotes and FAQs
Bentley Homepage
Bentley LEARN Server
