| Version(s): | N\A | ||
| Area: | DWG | ||
| Subarea: | Save | ||
When exporting to DWG, fonts are not filled and clip masks are not shown.
Font mapping was suggested for the MicroStation filled fonts to a true type font, using text with a background set instead of using masking, and setting the update sequence for controlling where the image displayed (background, foreground, etc.)
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0108247
