| Version(s): | V8 | ||
| Area: | DWG | ||
| Subarea: | Save | ||
How the Tag placement & attribute changes can affect the naming convention of cells/blocks when saving to DWG?.
Product: MicroStation
Version: V8
Area: DWG-Save
When the option 'Create Single Block for Duplicate Cells' is toggled ON
when Saving to DWG, if the placement of the tag varies on the same
subsequent cell names, a Unique cell name will always be created even
when this option is ON. This is also the case for Attribute changes to
each cell.
Suggestion:
To ensure that a single Block name is created, attach the Tag in the
same location for each cell.
