Recalc: 3. Dynamics
The relevant parameters for dynamic calculations in RM Bridge Enterprise are set in the Recalculation Window at the Dynamics / Iteration options within the Dynamics group. They are:
g - gravity (constant acceleration of gravity)
dt - time step (length for Time History - TH)
c1 - delta integration constant (for Newmark time integration method)
c2 - alpha integration constant (for Newmark time integration method)
Alfa - Mass coefficient (for damping matrix)
Beta - Stiffness coefficient (for damping matrix)
Xsi - Global damping ratio of actual to critical (for modal superposition)
Tol - Mass tolerance (for natural modes)
RM mode superposition method - to get the maximum of all components of the result vector independently from each other (with a factorized natural mode)
communities.bentley.com/.../rm-bridge-analyzer-recalculation-window
