| Version(s): | 08.05.02.35 | ||
| Area: | DWG | ||
| Subarea: | Save | ||
How to control the smoothness of curved solids when saving to DWG.
Product: MicroStation V8 2004 Edition
Version: 08.05.02.35
Area: DWG In/DWG Out, DEFINEDSTEPS
See Also: Help documentation: "Guide to Using DWG and Other Formats
For ACIS Entity export: the control for smoothness is determined by the
current Stroke Tolerance.
Go to Settings > Rendering > General.
For Polyface Mesh Entity export: the control for smoothness is
determined by the DWG option "Polyface Mesh Tolerance Angle"
Go to DWG Options > General > Advanced
