| Version(s): | 08.05.02.35 | ||
| Area: | DWG | ||
| Subarea: | Save | ||
How to remove XDATA from an imported dgn file
Product: MicroStation PDF Composer 2004 Edition
Version: 08.05.02.35
Area: DWG-Save
You must save the .dgn (that has the Xdata) back to a DWG file,ensuring to UNCHECK the "save Application Extended Data (XDATA)" box.
This dialog is located on the
OPTIONS > Advanced > Application data > Save
Application Extended Data (uncheck this box).
The OPTIONS button is on the "SAVE AS" dialog box.
