| Version(s): | All | ||
| Area: | STAAD.Pro Analysis Solution | ||
| Subarea: | Seismic Analysis | ||
| Original Author: | SANJIB DAS, Bentley Global Technical Support Group | ||
There has been an amendment # 2 to IS1893(Part-1)-2016 published in November 2020. It provides the following guideline-
Under the aforementioned sitations, one should generate Equivalent Static IS1893(Part-1)-2016 load case or IS1893(Part-1)-2016 Response Spectrum load case.
