| Version(s): | All | ||
| Area: | Steel Design | ||
| Subarea: | IS 800:2007 | ||
| Original Author: | Surojit Ghosh | ||
This warning message is related to the minimum web thickness check according to cl.8.6.1. For each member, program performs the web thickness check according to cl.8.6.1.1 - Serviceability requirement and cl.8.6.1.2 - Compression Flange buckling requirement. If any of the criteria mentioned in the above mentioned clause is not satisfied, a warning message is reported in the output file informing the exact clause number. It is required to modify the web dimension (increase the web thickness or decrease the depth).
