Load Case # XX is already defined in a previous envelope. The load case of final envelope type will
 Product(s):STAAD.Pro
 Version(s):All
 Environment: N/A
 Area: Steel Design
 Subarea: IS 800:2007
 Original Author:Surojit Ghosh
** WARNING: Load Case # XX is already defined in a previous envelope.
The load case of final envelope type will override previous envelope type attributes.
The meaning of the warning message is – same load case cannot be present in two separate types of load envelopes. If same load case is specified in different load envelopes, program considers the last envelope type for those load cases present in both the load envelopes. For example, consider the following load envelopes --
DEFINE ENVELOPE
100 110 120 121 ENVELOPE 1 TYPE STRENGTH
100 110 125 126 ENVELOPE 2 TYPE SERVICEABILITY
For these load envelopes, load case 100 and 110 is present in both the load envelopes. So these load cases will be treated as service load cases considering the load envelope type of the last load envelope.
It is required to define separate load cases in separate load envelopes.
