| Version(s): | 08.11.07.443 | ||
| Area: | GUI | ||
| Subarea: | General |
When using a display with high resolution, often all the icons and buttons in MicroStation appear relatively small.
In one particular incident a user was working on a Mac computer.
Standard the icons can be resized as follows:
As mentioned, the user was working on a Mac computer, emulating Windows with Bootcamp (recommended), equipped with a Retina display. So the standard solution did not work.
What solved the issue in this case was switching of the Retina settings under Windows.
Following links are to articles related to Retina settings (not tested/supported by Bentley):
http://arstechnica.com/apple/2012/07/windows-and-os-x-boot-camp-running-redmond-at-retina-resolution/
http://www.theverge.com/2013/6/26/4465442/windows-8-1-will-finally-add-retina-display-support
http://kb.parallels.com/en/114700
| Original Author: | Rene vandenBrink |
