| Version(s): | All | ||
| Area: | General Solutions | ||
| Subarea: | General Information | ||
| Original Author: | Global Technical Support | ||
I want to Change / Modify the displayed name in STAAD.Pro output header. For example, in attached image it was displaying as Bentley Systems, Inc. and I would like to change it to Bentley,
There is a file in the engine folder (by default, C:\Program Files\Bentley\Engineering\STAAD.Pro CONNECT Edition\STAAD\SProStaad\COUNTRY.TBL).
The banner used in the output is collected from that file.
For changing the content of the banner, administrative privilege is needed.
