| Version(s): | 10.00.00.25 | ||
| Environment: | Windows 8 | ||
| Area: | GUI | ||
| Subarea: | General |
How do I get more than 10 recently used documents visible on the Open page in MicroStation CONNECT Edition?
When you would like to see more than 10 recently used documents on the Open page, by pinning your most recently used files, you can list more than 10 documents on the Open page.
By setting the 'Show Details' -view you can see e.g. the full path for the document, file size and last modified time stamp right away.
Also scroll bar appears on the right hand side when the amount of pinned documents increase.
| Original Author: | Anu Kuusiaho |
