| Version(s): | 08.09.04.88 | ||
| Area: | GUI | ||
| Subarea: | General | ||
Pull-down menus are extending past the screen. The menu items can not be
selected. Menus too long.
MicroStation
08.09.04.88
Interface
Set the variable MS_NATIVEMAINMENU =1 will add arrows at the top and
bottom of long pull-down menus. The arrows will allow you to scroll up
and down in the menu list.
Other Language Sources
