| Version(s): | 08.05.01.25 | ||
| Area: | DWG | ||
| Subarea: | Save | ||
How to maintain the level display when saving to DWG.
When saving to DWG all the levels are turning on, even though some
levels are turned off.
Product: MicroStation V8 2004 Edition
Version: 08.05.01.25
Area: DWG
In the DWG Save As DWG/DXF Options under the general tab>Level Display>Select the view in which the levels are on/off.
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0110369
