Document Information
Document Type: FAQ
Product(s): LEAP BRIDGE CONCRETE
Version(s): All
Original Author: Bentley Technical Support GroupĀ -VM
QUESTION: How LBC performs LFD and ASD service design check?
ANSWER:
If user selects only service groups under LFD, then the program is performing ASD design check.
If user selects both Service + Strength groups, then the program is performing normal design as per LFD design check.
