| Version(s): | 10.05.00.40 | ||
| Area: | Installation | ||
| Subarea: | Updates |
Straight after upgrading MicroStation CONNECT Edition to the Update 5 version it crashes immediately on startup at the point ProjectWise Explorer Client is connecting.
It was found that ProjectWise Explorer Client CONNECT Edition 10.00.01.67 was incompatible with Update 5 of MicroStation CONNECT Edition. It is suggested to upgrade to the latest release of 10.00.02.265 which is available from the Software Download page on the CONNECTION Centre.
Software Download Instructions
| Original Author: | Andrew Bell |
