| Version: | 08.11.09.459 | ||
| Area: | Installation | ||
| Subarea: | General |
MicroStation or PowerDraft have been uninstalled from the computer using the Control Panel > Programs and Features tool but the programmes were not removed. Desktop shortcut icon remains and the programmes still open and work on the computer.
The programmes can be uninstalled using the .msi file
By default, the standard locating for this file is C:\BentleyDownloads\.........
Double click the MicroStation.msi or PowerDraft.msi
The Setup Wizard starts, click on Next
Three options should be listed, Change, Repair and Remove
Choose Remove and then select Next
The programme should uninstall, select Finish to complete
| Original Author: | Conor King |
