| Version(s): | 08.11.09.357 | ||
| Area: | Installation | ||
| Subarea: | General | ||
| Original Author: | Joshua Kulp, Bentley Technical Support Group | ||
V8i installation paths
Where is MicroStation V8i installed by default?
Where is PowerDraft V8i installed by default?
Where is View V8i installed by default?
MicroStation V8i
Machines with no prior MicroStation installation:
C:\Program Files\Bentley\
C:\Documents and Settings\All Users\Application
Data\Bentley\MicroStation\
Machines with prior installation of MicroStation:
Single/Normal install - must click Advanced to change paths
Delivered program directory: C:\Program Files\Bentley\MicroStation V8i\
Delivered workspace directory: C:\Documents and Settings\All
Users\Application Data\Bentley\MicroStation\
Multi-Install - must click Advanced to change paths
Multi-Install\MicroStation V8i\
Users\Application Data\Bentley Multi-Install\MicroStation\
PowerDraft V8i
Machines with no prior PowerDraft installation:
C:\Documents and Settings\All Users\Application Data\Bentley\PowerDraft\
Machines with prior installation of PowerDraft:
Delivered program directory: C:\Program Files\Bentley\PowerDraft V8i\
Multi-Install\PowerDraft V8i\
Users\Application Data\Bentley Multi-Install\PowerDraft\
Bentley View V8i
Machines with no prior View installation:
C:\Documents and Settings\All Users\Application Data\Bentley\View\
Machines with prior installation of View:
Delivered program directory: C:\Program Files\Bentley\View V8i\
Delivered program directory: C:\Program Files\Bentley Multi-Install\View
V8i\
Users\Application Data\Bentley Multi-Install\View\
