STAAD.Pro provides two main workflows for creating model geometry, both of which are included in these resources:
Learn how to model structural members in the STAAD.Pro Analytical Modeler or the STAAD.Pro Physical Modeler.
Download the Project Workbook and Dataset to access the hands-on, step-by-step instructions.
Learn how to assign properties and specifications to members in the STAAD.Pro Analytical Modeler or the STAAD.Pro Physical Modeler.
Learn how to model loads in the STAAD.Pro Analytical Modeler or the STAAD.Pro Physical Modeler.
Learn how to model plates and surfaces in the STAAD.Pro Analytical Modeler or the STAAD.Pro Physical Modeler.
Want to learn more? See the additional resources for modeling topics in STAAD.Pro.
Need help? Connect with us using the Bentley Support Portal.
