Designing Steel Structures in STAAD.Pro
STAAD.Pro can design steel structures for a variety of US and International design standards: Available Steel Design Codes
Learn how to design steel structures in STAAD.Pro CONNECT Edition.
 Download the Project Workbook and Dataset to access the hands-on, step-by-step instructions.
Designing Steel Structures for Deflection
Learn how to design steel structures for deflection in STAAD.Pro CONNECT Edition.
Optimizing Steel Structures
Learn how to optimize steel structures in STAAD.Pro CONNECT Edition.
Designing Steel Connections
Learn how to design steel structures in STAAD.Pro and RAM Connection. Learn how to use connection tags STAAD.Pro CONNECT Edition to streamline your connection design workflow.
Generating Working Drawings using the Steel AutoDrafter
Learn how to generate working drawings in STAAD.Pro using the Steel AutoDrafter.
Additional Resources
Want to learn more? See the additional resources for modeling topics in STAAD.Pro.
 Knowledge Base ArticlesRAM|STAAD ForumSTAAD Ideas PortalSTAAD Product Information
 STAAD Analytical Modeler TrainingSTAAD Physical Modeler TrainingSTAAD Technical DiscussionsSTAAD Tips and Tricks
 STAAD Coffee Corners (NAOU)STAAD/RAM Coffee Corners (EMEA)STAAD Coffee Corners (SEAPAC)RAM Coffee Corners (NAOU)
Need help? Connect with us using the Bentley Support Portal.
