| Applies To | STAAD.Pro | ||
| Product(s): | STAAD.Pro V8i & STAAD.Pro CE | ||
| Version(s): | 20.07.10.41 and later | ||
| Environment: | All | ||
| Area: | General Solutions | ||
| Subarea: | Configuration Settings | ||
| Original Author: | Payel Sasmal | ||
Problem Description
I am accidently using STAAD.Pro Advanced Analysis Engine, STAAD.beava (Bridge Codes), STAAD Planwin and RAM Connection and I’m getting invoice for the usage. Can these be deactivated within STAAD.Pro?
To avoid using STAAD.Pro Advanced Analysis Engine, STAAD.beava and Building Planner (STAAD Planwin) follow the steps as mentioned below.
For Connect Edition:
On the STAAD.pro CONNECT Edition Open screen, in the lower right corner, make sure that the check boxes are unchecked if you do not want to utilize any of the additional modules.
For V8i Version:
To avoid using the RAM Connection license, follow the steps as mentioned below.
STAAD .Pro CONNECT Edition
On the STAAD.pro CONNECT Edition Open screen, in the lower right corner, make sure that the RAM Connection box is unchecked if you do not want to utilize a RAM Connection License.
Tips for Using RAM Connection within STAAD.Pro [TN].
Other language sources
