Temporary local folder specified for analysis does not exist or is not accessible
Product(s):STAAD.Pro
Version(s):Connect Edition
Environment:ALL
Area:General Solutions
Subarea:Configuration Settings
Original Author:Payel Sasmal, Bentley Technical Support Group
Problem Description
After I am running the analysis it says "Temporary local folder specified for analysis does not exist or is not accessible!".
Please follow the ateps as stated here.
  1. Close all STAAD.Pro applications.
  2. Right-click on STAAD.Pro icon and choose “Run as administrator” option to open STAAD.Pro.
  3. Click on Configure option and follow the steps as shown here.
     4.   Re-open the model and this will work fine.
See also
STAAD.Pro general solutions
