| Version(s): | N\A | ||
| Area: | Standards | ||
| Subarea: | Templates |
The following key-in(s) can be used to set the active Element Template and turn on the Element Template Association lock. Useful for placing behind a Function Key or Customized Button.
An Element Templates is a named set of predefined element properties that can be used to set the active settings when placing elements, or applied to existing elements. The active Element Template is typically set by selecting the Template through the Ribbons 'Attributes' group by selecting the down arrow and navigating to the required Template.
In addition, when placing an element with the active Element Template, it is possible for the element to be associated to the Template, such that if the Template properties are changed all elements associated with that template are also changed. To enable this the Element Template Association icon next to the Element Template name needs to be selected ( Depressed background )
2. Enter the Key-in 'Template Active TemplateGroup\TemplateName'
Enter the Key-in 'Lock Templateassociation On'
It is possible to combine the keyins using the ';' to seperate them. In this example the Active Element Template 'RailwayLine' from the Template Group 'Rail' will be used to place a Smart Line which is associated to the Template via keyin
Enter the Key-in 'lock templateassociation on;template active Rail\RailwayLine;place smartline'
Place the Smart Line
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0055522
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0055242
