Bridge Deck is not available in the list of Workflow
Product(s):STAAD.Pro
Version(s):ALL
Environment:ALL
Area:General Solutions
Subarea:Configuration Settings
Description
I was working on Staad.Pro and I want to conduct the analysis for a bridge deck. The workflow window in my software does not show Bridge Deck Workflow option. It seems like I need a separate License for that.
You do not need a separate license for Bridge Deck workflow. This is included with STAAD.Pro license.
To access it, go to configure (the left most pane of STAAD.Pro) -> workflow and check the box for bridge deck as shown in the following image.
See Also:
What's New in STAAD.Pro CONNECT Edition V22 Update 6
