| Version(s): | ALL | ||
| Environment: | ALL | ||
| Area: | General Solutions | ||
| Subarea: | Configuration Settings | ||
| Original Author: | Abhisek Mandal, Bentley Technical Support Group | ||
May I know how to convert a 3d space analysis to 2d analysis?
You can do it from the input editor. Please open the input editor file and change the first line from STAAD SPACE to STAAD PLANE. Refer the attached pdf to know more about it.
