| Version(s): | Connect Edition | ||
| Environment: | ALL | ||
| Area: | General Solutions | ||
| Subarea: | Configuration Settings | ||
| Original Author: | Aaradhya Rahate, Bentley Technical Support Group | ||
When STAAD.Pro is launched, the application will present a message dialog box as shown in below image, that will report which licenses will be used in the session.
If you do not wish for dialog box, you can simply uncheck the show on start-up option as shown in below image and continue.
