| Version(s): | All | ||
| Area: | General Solutions | ||
| Subarea: | Configuration Settings | ||
How can I convert single line input to multiple line input? The program currently converts my joint coordinate and member incidence data from multiple line to single line input.
Start STAAD.Pro. Select File - Configure.
Click on the tab called Input File Format
If you want Single line format, switch on the check boxes. If you want Multiple line format, keep them "unchecked".
Click on Accept.
Then from the File menu, open your STAAD input file. When you Save the file from the Graphical screen, the data will be saved in the format you chose in the step above.
