Product(s): | MicroStation | ||
Version(s): | N\A | ||
Environment: | N\A | ||
Area: | Parametrics | ||
Subarea: | Constrains |
How to apply and edit a Radial dimensional constraint
Applying a Radial dimensional constraint to a Circle or Arc is done using the Dimension Element Constraint tool, which can can be found under
Ribbon: Drawing > Constraints > Dimensional
Ribbon: Modeling > Constraints > Dimensional
Select the Circle or Arc to be constrained
In the Tool Settings window select Radius (or Diameter)
4. Place a Data point to place the dimension, a pop up will display the current size and you have three options
Type in a new value and enter another data point in the view to except (The graphics will also change with new value)
If defined pick a Variable to be applied and enter another data point in the view to except (The graphics will also change with new value)
Move the cursor over the Dimension to edit and Right mouse click and select ' Edit Dimension '
3. Enter a new value or pick from the available list and enter a data point in the view to except
