| Version(s): | V8, V8i, CONNECT Edition | ||
| Area: | Dimensions | ||
| Subarea: | Notes | ||
How to have "in-line leader" on by default when you place a note
Product: MicroStation
Version: V8, V8i, CONNECT Edition
Area: Dimension/Measure
Element > Dimension Styles > Place Note > Toggle ON "In-line Leader"
(CONNECT Edition) Place Note tool > Dimension Style > Text > Note > Toggle ON "In-line Leader"
