| Version(s): | 08.05.02.35 | ||
| Area: | Dimensions | ||
| Subarea: | Dim Styles | ||
What is the key-in to close the Dimension Style dialog box?
In MicroStation V8.x, use the key-in: MDL UNLOAD DIMSET.
In MicroStation V8 XM Edition, use the key-in: MDL UNLOAD DIMSTYLE.
