Applies To | |||
Product(s): | STAAD Advanced Concrete Design | ||
Version(s): | Connect Edition | ||
Environment: | |||
Area: | Concrete Design | ||
Subarea: | General | ||
Original Author: | Aaradhya Rahate, Bentley Technical Support Group | ||
Procedure for Creating *.Mdb file & Linking with *.Edb
Direct Linking with Etabs 2015 & 2016 involves 2 easy steps as explained in the subtopics of "Creating *.mdb" & "Linking with *.edb"
Following points explain the 2 steps for Etabs 2015 & 2016 direct linking with RCDC.
STEP 1: Creating*.mdb.
STEP 2: Linking with *.Edb
2. While RCDC links to Etabs for data extraction, Etabs file will be opened at back for an instance and then will be automatically closed.
3.In case if the model contains steel sections, then RCDC will require *.e2k file too along with *.edb and *.mdb file with same name to be present in the same folder.
