Connect Advisor:
Bentley CONNECT Advisor, an in-product tool to access context relevant learning material.
Bentley CONNECT Advisor is installed with CONNECT Edition applications based on MicroStation CONNECT Edition Update 4 or later. It was offered as a Technology Preview in Update 4, then became a fully-fledged feature from Update 5 onwards.
Updates to the CONNECT Advisor feature are delivered during quarterly application updates. Each individual CONNECT Edition contains its own CONNECT Advisor feature so it is possible to have multiple instances running if more than one application is in use.
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0112567
Training: CONNECT Advisor
