Enhancements in Open Bridge Modeler version 10.11.00.310 (part of Open Bridge Designer version 10.11
OpenBridge Modeler (OBM)
- Deck Breakbacks
- User Defined Templates for Footings
- Tech Preview: Integrated Generative Components Workflow
- Wingwall top slope definition
- Wingwall vertical offset
- Approach Slab elevation report
- Inverted Tee Pier Cap: option to follow crown slope
- Cheek Walls can now be chamfered or filleted
- Bearing seat – adjust for skewed Pier/Abutment
- Bearing seat – adjust for Chamfer or Fillet
- Cross Frames: Option to orient connector plate along diagonals
- Cross Frames: Option to use member Center of Gravity
- Cross Frames: Option to use Double Angles/Level Connectors
- Cross Frames: Vertically Center
- Add Linear Templates Commands
- Wizard – options to not generate supports,
- Wizard - now allows copy/paste on Materials tab
- Rotate Individual Piles
- Min/Max on Parametric cells
- Concrete Diaphragm – at interior Piers
- Concrete Beams – Vertical/Normal
- Transfer Steel Tubs to LBS and RM
- Input Echo Report for Custom Pier or Abutment
- Config Variable to control display of Item Types in Properties Panel
- Config Variable to control display of Item Types in Tool Settings
- Config Variable to control length of Bearing Support Lines
- Pay unit for Barriers
- Named Points on Deck Elevation Reports
- Now uses File Settings for Auto-Save Design Changes
- Separate Levels for Bearings Decorators and Text
- Certified on Windows 11
- Support for ProjectWise Drive
- Haunch Material
- Config Variable to not display older ref file schema message
- Explicit Copy button on Beam definition dialog
- About OBM link directly on the Help Tab
- Deck Template, now easier to update values
- Support Line Label no longer adds B
- Reports & Drawings Tab: Minor Ribbon Change
- Installation, new option to install local documentation
- New Sidewalk elements added in the library
- Import Horizontal Points from ASCII File
- Item Types: EC Expression & Expression Builder
- Item Types: Bridge Structure # for all elements
- Concrete Diaphragm, Horizontal offset
- MicroStation PowerPlatform Update 17 (v10.17.00.981)
- CIF/OpenRoads 2022 Release 1 (v10.11.00.551xx)
- ProStructures Update 7.x (v10.07.00.xx)
- Certified with PW v10.00.03.453
- Generative Components (v10.17.0.42)
- GINT (10.0.0.32)
- Descartes (10.17.0.155)
- CONNECTION Client (11.00.04.15)
