| Version: | 08.11.09.459, 08.11.09.829 | ||
| Area: | Administration | ||
| Subarea: | N/A |
How to install MicroStation without an internet connection, or without entering the proxy username and password.
The MicroStation V8i (SELECTseries 3 and 4) installer attemps to contact the internet to download and install prerequisite components as well as the Bentley Visualization Content. If you don't have an internet connection, or if you have a proxy and don't enter in the username and password the installation wizard will hang until you connect to the internet or enter in the proxy information.
After you've downloaded and installed the Pre-requisite Pack, and Bentley Visualization Content you can now install MicroStation and the installer should not attempt to connect to the internet.
| Original Author: | Tamicca Sellars, Bentley Technical Support Group |
