| Version(s): | 08.05.01.25 | ||
| Area: | Hardware / Input Devices | ||
| Subarea: | N\A | ||
Wintab32.ini permission problem - Running the Bentley Wintab digitizer driver 01.00.45.00 on a WinXP machine.
An attempt to change the Wintab configuration causes MicroStation to hang, requiring an "End Task".
Version: 08.05.01.25
Product: MicroStation
V8 2004 Edition
Area: Hardware / Input Devices
User requires permission to write to the Windows directory in XP.
That is where the Wintab32.ini file resides and it holds all configuration settings for the digitizer.
An administrator will need to log on to change the file.
