| Version(s): | 08.09.02.77 | ||
| Area: | Drawing Aids | ||
| Subarea: | AccuDraw | ||
| Original Author: | Daniel Abney, Bentley Technical Support Group | ||
How to give focus to AccuDraw.
Product: MicroStation V8 XM Edition
Version: 08.09.02.77
Area: AccuDraw/AccuSnap
Press ESC and then Spacebar
1. Press ESC key (to put focus at home, if not already).
2. Press Spacebar.
Focus should now be at AccuDraw.
Notes:
This method will work provided that Position Mapping (on by default) is
enabled in preferences.
Activate AccuDraw with a Snap
and
MicroStation Help: "Controlling the Focus" (Contents - Getting Started -Fundamentals - MicroStation and Keyboard Input)
