| Version(s): | N\A | ||
| Area: | Dimensions | ||
| Subarea: | Dim Styles |
How to update modified dimension styles in a DGN to reflect those defined in the configured company standard DGNLIB file.
When a designer places a dimension in a DGN using a Dimension Style that has been predefined in a DGNLIB file the Dimension Style is copied to the DGN. Thus, if the Designer then edits the this Dimension Style, they are editing the local copy stored in the DGN so it's no longer in sync with the DGNLIB.
The Dimension Style dialog shows a Dimension Style is out of sync with the configured DGNLIB Dimension Style with a blue Triangle.
Select the 'Update From Library' tool on the Dimension Styles Dialog
Enter the keyin 'dgnlib update dimstyles'
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0108564
Other Languages Sources
