| Version(s): | 08.11.09.459 | ||
| Area: | Drawing Aids | ||
| Subarea: | AccuDraw | ||
| Original Author: | Alessandra Fugazzi, Bentley Technical Support Group | ||
After installing a localized version of MicroStation V8i SS3 Accudraw Keyboard Shortcuts such as <Enter> and <Space> do not work.
Exit MicroStation completely
Move "shortcut.txt file" (the Accudraw shortcut file) to a different location (example:Desktop). To find Shortcut.txt: WorkSpace > Configuration. Look for and select MS_ACCUDRAWKEYS. Under "Expansion" you will find the path to shortcut.txt
When launching MicroStation again a new "shortcut.txt" file should generate --The Accudraw Keyboard Shortcuts should now work.
When using the key-in ACCUDRAW SHORTCUTS DEFAULT any changes that were made by the user will be lost as this key-in is used to set shortcuts back to the defaults:
accudraw shortcuts default
and press Enter
Other Language Sources
