| Version(s): | 08.11.09.829 | ||
| Area: | Printing | ||
| Subarea: | N\A | ||
| Original Author: | Leonard Jones, Bentley Technical Support Group | ||
Support for Sharing Printed PDFs on the Cloud has now been added to MicroStation V8i SELECT series 4. You can share your printed PDFs on the cloud. This enables sharing of your published content with other users.
In the Print Dialog, Tick the "Publish PDF to Personal Share" option.
File > Print in Print Organizer
Bentley Cloud Services Overview
Other Language Sources
