| Version(s): | 08.00.00.00 | ||
| Area: | Tags | ||
| Subarea: | N\A | ||
How to drop the association of tags to elements and re-associate them to other elements.
Product: MicroStation V8
Version: 08.00.00.00
Use the key-in CHANGE TAGS DROPASSOC to drop the association of a tag set to an element.
To re-associate tags to an element:
(1) Select the tags to re-associate to an element.
(2) Key-in: CHANGE TAGS REASSOC
(3) Select the element to which the tags are to be re-associated.
