Document Information
Document Type: FAQ
Product(s): LEAP RCPier
Version(s): All
Original Author: Bentley Technical Support Group -VM
QUESTION: Does the program calculate the dead loads of the Wingwall and Approach slab?
ANSWER:
If the Approach slab information is added in the program, then in DC load case the user can generate just the approach slab loads on abutment as a force and moment.
Currently we don’t have an option to automatically generate the wing wall self-weight load on abutment and wingwall is only for modeling purpose.
Similar to how the approach slab load is applied, user can manually apply the self-weight load of the wingwall under the “Cap/Stem loads” as a “Force or UDL load”.
