In RAM Connection, Column Base (CB) Joints can be created with the following configurations:
Connector | Design Code | Column Section | Joint/Connection Options |
The Analysis Axis for each base plate defines the axis of analysis and design:
Connector | Design Code | Column Section | Brace Section | Joint/Connection Options |
In RAM Connection, seismic provisions can be incorporated into the design of the following connection templates:
In the New Joint dialog, the seismic load resisting system and seismic design parameters can be specified vertical braced frame joints where seismic provisions are considered:
