RM Bridge EXAMPLES
RM Bridge installation includes several examples that can be found at File\Examples, as shown in the screenshot below, where the following options are available:
communities.bentley.com/.../rm-bridge-demo-examples-and-faqs
communities.bentley.com/.../rm-bridge-verification-examples
communities.bentley.com/.../rm-bridge-training-examples
Examples
Each option contains a list of examples that can be used for learning purposes. Titles indicate the subject and one reference picture is shown to make the selection easier. The datasets can be loaded/imported and the examples calculations run. A subdirectory in the current project directory is normally created to allow for the analysis of the demo example; however, the user may select any other directory. All listed examples have a description document including a theoretical background in the .pdf format, and more general information can be found at each of the links above and their respective specific examples Knowledge Base articles.
