Associate a ProjectWise Project with Your File
To Associate a ProjectWise Project with Your File
When you create a new file or open an existing file which is not associated with a project, use the following procedure to associate your file with a ProjectWise Project.
Note: You must be signed in using the CONNECTION Client to associate a ProjectWise Project with your file.
Tip: If you want to change the ProjectWise Project associated with your file, use the same following procedure.
or
Select the CONNECTED Project tool.
The Assign Project dialog opens.
Note: Only users with Admin/Co-admin roles can register a project.
Tip: Alternately, you can visit connect.bentley.com and select +New on the Recent Projects tile on your personal dashboard.
