Chord and Branch Joints
In RAM Connection, Chord and Branches (CHB) Joints can be created with the following configurations:
Tubular Truss Connections
In RAM Connection, chord and branch joints for tubular truss connections can be created with the following configurations:
Connector
Design Code
| Chord Section | Branch Section | Joint/Connection Options |
- AISC: Tubular Truss (CHB)
- AS: Tubular Truss (CHB)
- EN: Tubular Truss (CHB)
- NZS: Tubular Truss (CHB)
- Reinforcement: Flange or Side Plates optional for rectangular/square chords.
- Adjacent Branch Configuration for K Joints: Gapped or Overlapped
Gusset Truss Connections
In RAM Connection, chord and branch joints for gusset truss connections can be created with the following configurations:
Connector
Design Code
- AISC: Truss Gusset Branch (TGB)
- AS: Truss Gusset Branch (TGB)
- CSA: Truss Gusset Branch (TGB)
- EN: Truss Gusset Branch (TGB)
- NZS: Truss Gusset Branch (TGB)
- I-Shaped
- Rectangular
- Circular
- I-Shaped
- Angle/Double Angle
- Channel
- Tee
- Rectangular
- Circular
- Circular Rod
- Connection Type: Bolted or Welded
(Welded only option for Circular Rods) - Offset to Working Point
