| Version(s): | 08.11.09.459 | ||
| Environment: | Windows 7 64 bit | ||
| Area: | Text | ||
| Subarea: | General | ||
| Original Author: | Reginald Wallace, Bentley Technical Support Group |
How to edit stack fraction text without losing the fraction?
1. Edit stack fraction text.
2. Double-click on the stacked fraction this will bring up the "Edit Stack Fraction" feature
3. Change the numerator and denominator to desired value press OK button
4. Continue to edit text and then apply your changes
