Rotate view while using various tools
 Product(s):MicroStation
 Version(s):08.11.05.17
 Environment: N\A
 Area: Drawing Aids
 Subarea: General
How to rotate view while using a tool and return to active tool without pressing an extra key or button?
Shift + XButton 1 (Middle button) drag
In the default setup, dragging with Shift + XButton 1 (Middle button) will rotate the view until the button is released and then return you to your active tool.
You can configure MicroStation specific button assignments in the Button Assignments dialog from the Workspace menu.
