RM Bridge View
RM Bridge View is a post-processing structure and results viewer inside a module based on the MicroStation platform. It creates a .DGN file with only the selected load and superposition diagrams where an automated report can be generated. The RM View module inside RM Bridge Enterprise application allows:
You can see an example of how to use it in the video from our YouTube channel below:
https://youtu.be/sf2GBARIG0s
