| Version: | 08.11.09.459 | ||
| Area: | Levels | ||
| Subarea: | General |
How to remove unused levels from a DGN.
Select the menu item File > Compress > Options to open the Compress Options Dialog.
Place a checkmark against ' Delete Unused Levels '
Optional - Check the ' Include References ' option
Select ' Compress '
| Original Author: | Carl Myhill |
