| Version: | V8, V8i and CONNECT | ||
| Area: | Levels | ||
| Subarea: | General |
User is unable to delete levels in a file that have shared cell definitions in it.
First try the solution found in the Deleting Levels technote:
Deleting Levels
If that does not work follow the steps below:
